소개
The batteries in Sony® Handycams can sometimes require changing, either because they are overused and don't hold a charge, or because they have corroded (happens rarely). You can also have multiple batteries and be changing between them when they run out, without waiting for the camera to recharge.
Place thumb on the ridge of the battery door hatch.
Apply pressure horizontally to easily slide the door off.
Improper seating of the battery can lead to memory loss and even corruption, replacing a battery can be a simple way to solve sudden crashes of the device.
다른 2명이 해당 안내서를 완성하였습니다.
