주요 콘텐츠로 건너뛰기
Sony Handycam HDR-CX405 Battery Replacement
  1. Sony Handycam HDR-CX405 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Place thumb on the ridge of the battery door hatch.
    • Apply pressure horizontally to easily slide the door off.
  2. Sony Handycam HDR-CX405 Battery Replacement: 2 단계, 이미지 1/1
    • Using your thumb, push the small blue fastening clip down.
    • Slide old battery out of camera.
    • Release the blue fastening clip.
  3. Sony Handycam HDR-CX405 Battery Replacement: 3 단계, 이미지 1/1
    • Slide the new battery into the camera.
  4. Sony Handycam HDR-CX405 Battery Replacement: 4 단계, 이미지 1/1
    • Push battery door down so it is level with the original positioning.
    • Slide door shut.
결론
Improper seating of the battery can lead to memory loss and even corruption, replacing a battery can be a simple way to solve sudden crashes of the device.
다른 2명이 해당 안내서를 완성하였습니다.
Alexander Nery
회원 가입일: 03/04/16
255 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-6, Bhusal Spring 2016 UMass Dartmouth, Team 3-6, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S3G6
3 회원들
안내서 2개 작성하였습니다
댓글 한 개
What is that 2nd battery bay? There is a way of opening it?
Edmundo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 11
30일 전: 47
전체 시간: 3,628
