주요 콘텐츠로 건너뛰기
Sony Handycam HDR-CX675 Shutter Assembly Replacement
필요한 것
  1. Sony Handycam HDR-CX675 Shutter Assembly Replacement, Camera Shell: 1 단계, 이미지 1/1
    • The battery should be removed and oriented upwards.
  2. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 2 단계, 이미지 1/1
    • Remove the side 4.5 mm JIS #00 screw using JIS Screwdriver
    • Remove the 5.5 mm JIS #00 screw.
  3. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 3 단계, 이미지 1/2 Sony Handycam HDR-CX675 Shutter Assembly Replacement: 3 단계, 이미지 2/2
    • Gently pry the plastic case surrounding the start/stop button free by using the blue plastic opening tools.
    • Remove the casing using your thumb and index finger.
  4. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 4 단계, 이미지 1/1
    • Turn the camera around and flip open the LCD screen to expose the side panel.
    • Remove the 5.5mm #00 screw using the J00 head screwdriver.
  5. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 5 단계, 이미지 1/1
    • Turn the camera to the handgrip side and unscrew two of the 5.5mm JIS #00 head screws using the JIS #00 head screwdriver.
  6. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 6 단계, 이미지 1/1
    • Remove the two 5.5mm JIS #00 screws with the bottom of the camera facing up.
  7. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 7 단계, 이미지 1/1
    • Turn the camera around in a way that the bottom of the camera is facing you.
    • Use the blue opening tool to gently remove the camera shell off of the camera.
  8. Sony Handycam HDR-CX675 Shutter Assembly Replacement, Lens Cover Panel: 8 단계, 이미지 1/1
    • Using the blue plastic opener smoothly to take the camera shell off.
  9. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 9 단계, 이미지 1/2 Sony Handycam HDR-CX675 Shutter Assembly Replacement: 9 단계, 이미지 2/2
    • Let the lens of the camera be pointed to your left.
    • Keep holding the camera with your right hand then gently remove the lens cover panel with your left hand.
  10. Sony Handycam HDR-CX675 Shutter Assembly Replacement, Shutter Assembly: 10 단계, 이미지 1/1
    • Place the camera on its lens and keep the LCD screen open and pointed to your right.
    • Remove the 5.5mm JIS #00 screws from the hinge of the camera.
  11. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 11 단계, 이미지 1/2 Sony Handycam HDR-CX675 Shutter Assembly Replacement: 11 단계, 이미지 2/2
    • Hold the camera with your left hand, and gently remove the shutter assembly part.
  12. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 12 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Hold the camera that the bottom is upwards and lens pointed to your left hand.
    • By the metal tweezers, remove the white wire that is connecting the shutter assembly and motherboard
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mohamed Nazer
회원 가입일: 02/15/17
403 평판
안내서 3개 작성하였습니다
USF Tampa, Team 8-2, Eyestone Spring 2017 USF Tampa, Team 8-2, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S8G2
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 732
