소개
In this guide, you will learn how to remove the shutter assembly from the Sony Handycam HDR-CX675. Completely removing the shutter assembly must be done with caution, as it is connected to the motherboard with sensitive electrical ribbon.
필요한 것
Place the camera on its lens and keep the LCD screen open and pointed to your right.
Remove the 5.5mm JIS #00 screws from the hinge of the camera.
다른 한 분이 해당 안내서를 완성하였습니다.
