주요 콘텐츠로 건너뛰기
Sony ICF-C1T Speaker Replacement
필요한 것
  1. Sony ICF-C1T Speaker Replacement, Speaker: 1 단계, 이미지 1/2 Sony ICF-C1T Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, remove the four 14mm screws from the underside of the device.
    • Be sure that the device is unplugged and the battery has been removed before tampering with the device.
  2. Sony ICF-C1T Speaker Replacement: 2 단계, 이미지 1/1
    • Using the opening tool, gently pry the top portion from the side section of your device.
  3. Sony ICF-C1T Speaker Replacement: 3 단계, 이미지 1/2 Sony ICF-C1T Speaker Replacement: 3 단계, 이미지 2/2
    • Gently pull the top of the clock away from the rest of the device.
    • Be careful when tugging on this piece of the clock. The clock display is located directly inside the front face and is connected by multiple wires.
  4. Sony ICF-C1T Speaker Replacement: 4 단계, 이미지 1/2 Sony ICF-C1T Speaker Replacement: 4 단계, 이미지 2/2
    • Using the Phillips #00 screwdriver, remove the two 14mm screws from the top of the motherboard.
    • Be careful to avoid the sharp pieces on the motherboard when handling the device.
  5. Sony ICF-C1T Speaker Replacement: 5 단계, 이미지 1/3 Sony ICF-C1T Speaker Replacement: 5 단계, 이미지 2/3 Sony ICF-C1T Speaker Replacement: 5 단계, 이미지 3/3
    • Remove the Phillips #00 screw from the bottom of the white and blue box.
    • Remove the Phillips #00 screw from behind the white and blue box.
    • After unscrewing the white box, gently pull it out. This will allow for more room to access the speaker.
  6. Sony ICF-C1T Speaker Replacement: 6 단계, 이미지 1/1
    • To separate the motherboard completely, you can cut the red and black wires that are attached to the speaker. This will allow you to access the speaker fully.
    • Use caution when tampering with the wires and sharp parts of the device.
  7. Sony ICF-C1T Speaker Replacement: 7 단계, 이미지 1/2 Sony ICF-C1T Speaker Replacement: 7 단계, 이미지 2/2
    • Use the plastic opening tool and the spudger to separate the speaker from the device by tracing its outline and loosening the glue.
    • Do this step gently as to not damage the device or cause harm to yourself.
    • When reassembling the device, you will need to use glue to place the new speaker back in its place.
    • It would be wise to test the device after reconnecting wires, before screwing and gluing the parts back together.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Megan
회원 가입일: 01/30/15
275 평판
안내서 2개 작성하였습니다
댓글 한 개
can I connect aux out port to speaker?
Dong-Hwan Shin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 25
전체 시간: 2,636
