주요 콘텐츠로 건너뛰기
Sony ICF-C1T Tuner Dial Replacement
필요한 것
  1. Sony ICF-C1T Tuner Dial Replacement, Tuner Dial: 1 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove four 14mm screws from the underside of the device.
    • Make sure that the clock is unplugged and the battery is removed before tampering with the device to avoid electrical shock.
  2. Sony ICF-C1T Tuner Dial Replacement: 2 단계, 이미지 1/1
    • Use the opening tool to pry apart the edges of the top and side portions of the device.
  3. Sony ICF-C1T Tuner Dial Replacement: 3 단계, 이미지 1/2 Sony ICF-C1T Tuner Dial Replacement: 3 단계, 이미지 2/2
    • Separate the device by gently pulling up on the top portion.
    • Use caution when pulling the device apart as the clock display is located close to the front face plate and is connected by multiple wires.
  4. Sony ICF-C1T Tuner Dial Replacement: 4 단계, 이미지 1/2 Sony ICF-C1T Tuner Dial Replacement: 4 단계, 이미지 2/2
    • To remove the motherboard, gently pull apart the sides of the device.
    • Do not pull hard on the motherboard, because it is still connected by multiple wires inside the device.
    • Be careful of sharp pieces on the motherboard.
    • Having help for this step might make things quicker and easier.
  5. Sony ICF-C1T Tuner Dial Replacement: 5 단계, 이미지 1/3 Sony ICF-C1T Tuner Dial Replacement: 5 단계, 이미지 2/3 Sony ICF-C1T Tuner Dial Replacement: 5 단계, 이미지 3/3
    • Remove the tuner dial by pulling it off of the motherboard. This can take a little force to remove.
결론
Megan
회원 가입일: 01/30/15
275 평판
안내서 2개 작성하였습니다
댓글 한 개
Thanks, this was not fun but the guide helped.
Campbell Kerr - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 25
전체 시간: 1,579
