주요 콘텐츠로 건너뛰기
Sony ICF-C1iPMK2 Screen Replacement
필요한 것
  1. Sony ICF-C1iPMK2 Screen Replacement, Screen: 1 단계, 이미지 1/3 Sony ICF-C1iPMK2 Screen Replacement, Screen: 1 단계, 이미지 2/3 Sony ICF-C1iPMK2 Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Flip product over to see the back.
    • Remove the 1 cm Phillips #00 screws.
    • Use a plastic spudger to pry the back chassis off of the front.
  2. Sony ICF-C1iPMK2 Screen Replacement: 2 단계, 이미지 1/3 Sony ICF-C1iPMK2 Screen Replacement: 2 단계, 이미지 2/3 Sony ICF-C1iPMK2 Screen Replacement: 2 단계, 이미지 3/3
    • This step contains ribbon cables. Be careful to not bend or rip these fragile cables, to protect your device.
    • Open up the back.
    • Carefully remove the ribbon cables by pulling them straight out of the port.
  3. Sony ICF-C1iPMK2 Screen Replacement: 3 단계, 이미지 1/2 Sony ICF-C1iPMK2 Screen Replacement: 3 단계, 이미지 2/2
    • Remove the power connector.
    • Remove the aux cable connector.
  4. Sony ICF-C1iPMK2 Screen Replacement: 4 단계, 이미지 1/1
    • Slide buttons off the front chassis
  5. Sony ICF-C1iPMK2 Screen Replacement: 5 단계, 이미지 1/3 Sony ICF-C1iPMK2 Screen Replacement: 5 단계, 이미지 2/3 Sony ICF-C1iPMK2 Screen Replacement: 5 단계, 이미지 3/3
    • Remove the 1 cm screws from the plastic speaker cover using Phillips #00 screwdriver.
    • Gently pull the speaker cable out.
  6. Sony ICF-C1iPMK2 Screen Replacement: 6 단계, 이미지 1/3 Sony ICF-C1iPMK2 Screen Replacement: 6 단계, 이미지 2/3 Sony ICF-C1iPMK2 Screen Replacement: 6 단계, 이미지 3/3
    • Remove the plastic speaker cover from the left side.
  7. Sony ICF-C1iPMK2 Screen Replacement: 7 단계, 이미지 1/3 Sony ICF-C1iPMK2 Screen Replacement: 7 단계, 이미지 2/3 Sony ICF-C1iPMK2 Screen Replacement: 7 단계, 이미지 3/3
    • Remove the two 1 cm Phillips #00 screws.
    • Carefully pull out the ribbon cable.
    • Slide the iPod dock out.
  8. Sony ICF-C1iPMK2 Screen Replacement: 8 단계, 이미지 1/1
    • Gently push down and pull the screen out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
KyndleGabel
회원 가입일: 09/15/23
533 평판
안내서 3개 작성하였습니다
University of North Texas, Team 6-5, Kilpatrick Fall 2023 University of North Texas, Team 6-5, Kilpatrick Fall 2023 회원
UNT-KILPATRICK-F23S6G5
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 138
