주요 콘텐츠로 건너뛰기
Sony ICF-C1iPMK2 Speaker Replacement
필요한 것
  1. Sony ICF-C1iPMK2 Speaker Replacement, Speaker: 1 단계, 이미지 1/2 Sony ICF-C1iPMK2 Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Unscrew the 1 cm Phillips #00 screws.
    • Use spudger to loosen the back panel of the device.
  2. Sony ICF-C1iPMK2 Speaker Replacement: 2 단계, 이미지 1/3 Sony ICF-C1iPMK2 Speaker Replacement: 2 단계, 이미지 2/3 Sony ICF-C1iPMK2 Speaker Replacement: 2 단계, 이미지 3/3
    • This step contains ribbon cables. Be careful to not bend or rip these fragile cables, to protect your device.
    • Slowly pull the back panel off until it separated from the main panel.
    • Carefully unplug all of the ribbon cables connecting the back panel to the main panel.
  3. Sony ICF-C1iPMK2 Speaker Replacement: 3 단계, 이미지 1/3 Sony ICF-C1iPMK2 Speaker Replacement: 3 단계, 이미지 2/3 Sony ICF-C1iPMK2 Speaker Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the power connector with a pair of ESD safe tweezers.
    • Remove the Aux port connector with a pair of ESD safe tweezers.
    • Slide the button panels out of the chassis.
  4. Sony ICF-C1iPMK2 Speaker Replacement: 4 단계, 이미지 1/3 Sony ICF-C1iPMK2 Speaker Replacement: 4 단계, 이미지 2/3 Sony ICF-C1iPMK2 Speaker Replacement: 4 단계, 이미지 3/3
    • Unscrew the four 1 cm Phillips #00 screws and remove the speaker cover.
    • Unscrew the 1 cm Phillips #00 screws holding the speaker in place.
    • Remove the old speaker and insert the new one.
결론
KyndleGabel
회원 가입일: 09/15/23
533 평판
안내서 3개 작성하였습니다
University of North Texas, Team 6-5, Kilpatrick Fall 2023 University of North Texas, Team 6-5, Kilpatrick Fall 2023 회원
UNT-KILPATRICK-F23S6G5
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 88
