주요 콘텐츠로 건너뛰기
Sony Laptop VGN-FE31Z LCD Repair
필요한 것
  1. Sony Laptop VGN-FE31Z LCD Repair, Sony Laptop VGN-FE31Z LCD Repair: 1 단계, 이미지 1/1
    • This problem has already happened in many electronic devices in my home, almost every year. The solution is simple: to dismantle the machine completely and remove all traces of soil, ants and dirt.
    • Researching a little on Google, I found the repair manual of the Sony Vaio VGN FE31Z at this address: http://www.givemefile.net/smanuals/noteb...
    • Procedures carefully dismantling the equipment until the LCD. While performing this procedure, I noticed that the ants began to move from side to side, Laptop Keyboard leaving and entering the LCD.
    • The ants have focused on two points: the LVDS and backlight ballast.
    • I removed all electrical parts and proceeded to clean all plastic casing of the laptop, with water and detergent. While the coating was dry, I used isopropyl alcohol to clean the traces of soil. I applied a clean contact solution and the other in LVDS connectors.
    • I mounted the LCD, putting a little poison for ants to prevent future infestations.
결론
첨부 문서
Djair Guilherme
회원 가입일: 04/28/10
114 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 28
전체 시간: 2,432
