주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Sony M-430 Microcassette-Corder Cassette Lid Replacement
필요한 것
  1. Sony M-430 Microcassette-Corder Cassette Lid Replacement, Cassette Lid: 1 단계, 이미지 1/3 Sony M-430 Microcassette-Corder Cassette Lid Replacement, Cassette Lid: 1 단계, 이미지 2/3 Sony M-430 Microcassette-Corder Cassette Lid Replacement, Cassette Lid: 1 단계, 이미지 3/3
    • Using a spudger, apply pressure towards the back corner of the cassette compartment to the plastic tab directly behind the gold cone.
    • Pushing the tab allows the hinge to be separated from the body of the device.
    • The third picture shows the what the tab looks like when the device is disassembled, and illustrates the direction to apply pressure.
  2. Sony M-430 Microcassette-Corder Cassette Lid Replacement: 2 단계, 이미지 1/2 Sony M-430 Microcassette-Corder Cassette Lid Replacement: 2 단계, 이미지 2/2
    • Next, use a plastic opening tool to pull the metal latch towards the speaker.
    • The latch should be clear of the slot in the cassette lid.
    • Be careful not to bend the latch too far, as it may warp.
  3. Sony M-430 Microcassette-Corder Cassette Lid Replacement: 3 단계, 이미지 1/1
    • Carefully lift the cassette lid, making sure the tab and latch are free from connection.
결론
Scott
회원 가입일: 01/21/12
1 평판
안내서 1개 작성함
Cal Poly, Team 10-34, Amido Winter 2012 Cal Poly, Team 10-34, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G34
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 14
전체 시간: 1,401
