주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony M-430 Microcassette-Corder Mechanism Deck Replacement
필요한 것
  1. Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Cassette Lid: 1 단계, 이미지 3개 중 1개 Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Cassette Lid: 1 단계, 이미지 3개 중 2개 Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Cassette Lid: 1 단계, 이미지 3개 중 3개
    • Using a spudger, apply pressure towards the back corner of the cassette compartment to the plastic tab directly behind the gold cone.
    • Pushing the tab allows the hinge to be separated from the body of the device.
    • The third picture shows the what the tab looks like when the device is disassembled, and illustrates the direction to apply pressure.
  2. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 2 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 2 단계, 이미지 2개 중 2개
    • Next, use a plastic opening tool to pull the metal latch towards the speaker.
    • The latch should be clear of the slot in the cassette lid.
    • Be careful not to bend the latch too far, as it may warp.
  3. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully lift the cassette lid, making sure the tab and latch are free from connection.
  4. Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Find the arrow on the battery cover on the back of the device.
    • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
  5. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 5 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the cover and remove the batteries.
  6. Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Back Cover: 6 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Back Cover: 6 단계, 이미지 2개 중 2개
    • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
    • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
    • Potential for device damage: be careful not to apply too much force, as the lid may break.
  7. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 7 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 7 단계, 이미지 2개 중 2개
    • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
    • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  8. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 8 단계, 이미지 1개 중 1개
    • Use a spudger to push in the two tabs located on the bottom of the device.
    • It works best to push the tabs at an upward angle (towards the top of the battery compartment). It may take a decent amount of force in order to push in the tabs.
  9. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 9 단계, 이미지 1개 중 1개
    • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
    • The back cover should lift cleanly off.
  10. Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Motherboard: 10 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Motherboard: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers, pull upward on the black tape which secures the wires.
    • Removing this tape allows you to move the wires out of the way for the next step.
  11. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 11 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 11 단계, 이미지 2개 중 2개
    • Desolder all wires connecting components to the motherboard.
    • Be careful to not melt the solder points together.
    • A red wire and a blue wire connect the motor to the motherboard.
    • Two black wires connect the speaker to the motherboard.
    • A red wire and a black wire connect the microphone to the motherboard.
  12. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 12 단계, 이미지 1개 중 1개
    • After desoldering the microphone connections, pull the microphone straight out from the device and set aside.
    • Be careful not to tear the wires off of the microphone.
    • Removing the microphone gives you access to the green ribbon cable that connects to the mechanism deck.
  13. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 13 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 13 단계, 이미지 2개 중 2개
    • Desolder the 4 connections of the green ribbon cable.
    • Pull upward on the green ribbon cable to separate it from the motherboard.
    • Be careful when pulling up the film as it may tear.
  14. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 14 단계, 이미지 1개 중 1개
    • Using a #00 Phillips screwdriver, remove the two 1.4x3 mm screws securing the motherboard.
  15. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 15 단계, 이미지 1개 중 1개
    • If the replacement motherboard does not have the wire battery terminals attached, desolder the two battery connections on the motherboard.
    • Leave the wire battery terminals in place.
    • If the replacement motherboard has battery terminals attached, the connections do not need to be desoldered.
  16. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 16 단계, 이미지 1개 중 1개
    • To remove the battery terminals, use a prying tool to push the lip of the metal wire towards the motherboard.
    • Lift up on the wire while the small lip is depressed and slide the wire terminals out of the plastic guides.
    • Be careful not to bend the wire terminals.
  17. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 17 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 17 단계, 이미지 2개 중 2개
    • Verify all of the connections have been desoldered and the screws removed.
    • Lift the motherboard upward to remove it from the microcassette-corder.
  18. Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Mechanism Deck: 18 단계, 이미지 3개 중 1개 Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Mechanism Deck: 18 단계, 이미지 3개 중 2개 Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Mechanism Deck: 18 단계, 이미지 3개 중 3개
    • First, remove the buttons from the mechanism deck so that you can remove it from the case.
    • Find the tabs on each button.
    • Push the tab with a spudger away from the metal connection.
    • Pull button away from the mechanism deck to remove it.
  19. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: 19 단계, 이미지 1개 중 1개
    • Remove the mechanism deck by lifting the tab as shown.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Stephen
회원 가입일: 01/21/12
215 평판
안내서 2개를 작성함
Cal Poly, Team 10-34, Amido Winter 2012 Cal Poly, Team 10-34, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G34
4 회원들
안내서 7개를 작성함
3가이드 댓글
I have to replace the capstan wheel of the driving mechanism. where do I get the above part? its Part NO. and app cost please. Thank you
Char.jp - 답글 공유
I have cassettes, but recorder is not functioning for want of the capstan wheel of driving mechanism. Can you please help me with information
Char.jp - 답글 공유
I would greatly appreciate receiving some info regarding where to get parts or a full mechanism deck replacement for Sony M-607V microcassette recorder. Also if it is possible to get a Service Manual with exploded views.
Thanks in advance for any help.
Hermann
Hermann Hugo Holbut Arroyo - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 69
전체 시간: 7,286
