주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony M-430 Microcassette-Corder Microphone Replacement
필요한 것
  1. Sony M-430 Microcassette-Corder Microphone Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Find the arrow on the battery cover on the back of the device.
    • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
  2. Sony M-430 Microcassette-Corder Microphone Replacement: 2 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Microphone Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the cover and remove the batteries.
  3. Sony M-430 Microcassette-Corder Microphone Replacement, Back Cover: 3 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Microphone Replacement, Back Cover: 3 단계, 이미지 2개 중 2개
    • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
    • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
    • Potential for device damage: be careful not to apply too much force, as the lid may break.
  4. Sony M-430 Microcassette-Corder Microphone Replacement: 4 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Microphone Replacement: 4 단계, 이미지 2개 중 2개
    • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
    • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  5. Sony M-430 Microcassette-Corder Microphone Replacement: 5 단계, 이미지 1개 중 1개
    • Use a spudger to push in the two tabs located on the bottom of the device.
    • It works best to push the tabs at an upward angle (towards the top of the battery compartment). It may take a decent amount of force in order to push in the tabs.
  6. Sony M-430 Microcassette-Corder Microphone Replacement: 6 단계, 이미지 1개 중 1개
    • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
    • The back cover should lift cleanly off.
  7. Sony M-430 Microcassette-Corder Microphone Replacement, Microphone: 7 단계, 이미지 1개 중 1개
    • The microphone is the silver circular part above the buttons on your device.
    • A black and a red wire connect the microphone to the motherboard as shown in the bottom left of the picture.
  8. Sony M-430 Microcassette-Corder Microphone Replacement: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • The wires are held down with a piece of black tape.
    • Remove the tape with a pair of tweezers.
    • Potential for device damage: try not to pull the wires, as they might tear loose from their soldering connections
  9. Sony M-430 Microcassette-Corder Microphone Replacement: 9 단계, 이미지 1개 중 1개
    • Desolder the two connections between the wires and the motherboard. Make sure that the two solder points do not melt together.
  10. Sony M-430 Microcassette-Corder Microphone Replacement: 10 단계, 이미지 1개 중 1개
    • Now that the wires are disconnected from the motherboard, you can simply pull the mic out, away from the top of the device.
    • Potential for device damage: be careful to not detach the mic from its wires, as the connection between the wire and the mic itself is delicate.
결론
작성자
7다른 기여자 명과 함께
Matt Teare
회원 가입일: 01/20/12
35 평판
안내서 3개를 작성함
Cal Poly, Team 10-34, Amido Winter 2012 Cal Poly, Team 10-34, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G34
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 1,534
