주요 콘텐츠로 건너뛰기
Sony M-430 Microcassette-Corder Microphone Replacement
필요한 것
  1. Sony M-430 Microcassette-Corder Microphone Replacement, Battery: 1 단계, 이미지 1/1
    • Find the arrow on the battery cover on the back of the device.
    • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
  2. Sony M-430 Microcassette-Corder Microphone Replacement: 2 단계, 이미지 1/2 Sony M-430 Microcassette-Corder Microphone Replacement: 2 단계, 이미지 2/2
    • Lift the cover and remove the batteries.
  3. Sony M-430 Microcassette-Corder Microphone Replacement, Back Cover: 3 단계, 이미지 1/2 Sony M-430 Microcassette-Corder Microphone Replacement, Back Cover: 3 단계, 이미지 2/2
    • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
    • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
    • Be careful not to apply too much force, as the lid may break.
  4. Sony M-430 Microcassette-Corder Microphone Replacement: 4 단계, 이미지 1/2 Sony M-430 Microcassette-Corder Microphone Replacement: 4 단계, 이미지 2/2
    • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
    • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  5. Sony M-430 Microcassette-Corder Microphone Replacement: 5 단계, 이미지 1/1
    • Use a spudger to push in the two tabs located on the bottom of the device.
    • It works best to push the tabs at an upward angle (towards the top of the battery compartment)
    • It may take a decent amount of force in order to push in the tabs.
  6. Sony M-430 Microcassette-Corder Microphone Replacement: 6 단계, 이미지 1/1
    • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
    • The back cover should lift cleanly off.
  7. Sony M-430 Microcassette-Corder Microphone Replacement, Microphone: 7 단계, 이미지 1/1
    • The microphone is the silver circular part above the buttons on your device.
    • A black and a red wire connect the microphone to the motherboard as shown in the bottom left of the picture.
  8. Sony M-430 Microcassette-Corder Microphone Replacement: 8 단계, 이미지 1/1
    • The wires are held down with a piece of black tape.
    • Remove the tape with a pair of tweezers. Try not to pull the wires, as they might tear loose from their soldering connections
  9. Sony M-430 Microcassette-Corder Microphone Replacement: 9 단계, 이미지 1/1
    • Desolder the two connections between the wires and the motherboard. Make sure that the two solder points do not melt together.
  10. Sony M-430 Microcassette-Corder Microphone Replacement: 10 단계, 이미지 1/1
    • Now that the wires are disconnected from the motherboard, you can simply pull the mic out, away from the top of the device.
    • Be careful to not detach the mic from its wires, as the connection between the wire and the mic itself is delicate.
결론
Matt Teare
회원 가입일: 01/20/12
35 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-34, Amido Winter 2012 Cal Poly, Team 10-34, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G34
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 1,259
