주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony M-430 Microcassette-Corder Speaker Replacement
필요한 것
  1. Sony M-430 Microcassette-Corder Speaker Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Find the arrow on the battery cover on the back of the device.
    • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
  2. Sony M-430 Microcassette-Corder Speaker Replacement: 2 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the cover and remove the batteries.
  3. Sony M-430 Microcassette-Corder Speaker Replacement, Back Cover: 3 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Speaker Replacement, Back Cover: 3 단계, 이미지 2개 중 2개
    • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
    • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
    • Potential for device damage: be careful not to apply too much force, as the lid may break.
  4. Sony M-430 Microcassette-Corder Speaker Replacement: 4 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
    • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  5. Sony M-430 Microcassette-Corder Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Use a spudger to push in the two tabs located on the bottom of the device.
    • It works best to push the tabs at an upward angle (towards the top of the battery compartment). It may take a decent amount of force in order to push in the tabs.
  6. Sony M-430 Microcassette-Corder Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
    • The back cover should lift cleanly off.
  7. Sony M-430 Microcassette-Corder Speaker Replacement, Speaker: 7 단계, 이미지 1개 중 1개
    • The speaker is the large gold circular piece attached under where the batteries would normally be.
    • It is connected to the device with two black wires that run along one side of the motherboard, as shown on the top of the picture.
  8. Sony M-430 Microcassette-Corder Speaker Replacement: 8 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Speaker Replacement: 8 단계, 이미지 2개 중 2개
    • Depending on the replacement speaker you have, there are two places you can desolder the wire.
    • If your replacement speaker has a wire already attached to it, desolder the old wire from where it connects to the motherboard.
    • If the replacement speaker has no wire, desolder the old wire where it connects to the broken speaker.
  9. Sony M-430 Microcassette-Corder Speaker Replacement: 9 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Speaker Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Unscrew the 2 Phillips head screws (2x2.5 mm) around the edge of the speaker with a #00 Phillips screwdriver.
    • Use a pair of tweezers to remove the black tape on the speaker. Put the tape on the back of the new speaker.
  10. Sony M-430 Microcassette-Corder Speaker Replacement: 10 단계, 이미지 1개 중 1개
    • Now that the speaker is detached from the device, simply tilt the device over and let the speaker fall out.
결론
작성자
4다른 기여자 명과 함께
Matt Teare
회원 가입일: 01/20/12
35 평판
안내서 3개를 작성함
Cal Poly, Team 10-34, Amido Winter 2012 Cal Poly, Team 10-34, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G34
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 39
전체 시간: 1,149
