주요 콘텐츠로 건너뛰기
Sony MDR-XB450AP Extra Bass Headphones Cushion Replacement
필요한 것
  1. Sony MDR-XB450AP Extra Bass Headphones Cushion Replacement, Cushion: 1 단계, 이미지 1개 중 1개
    • Begin by laying the headphones down flat on a surface.
    • Make sure that the headphone speakers are facing upward.
    • Be sure to check that the headphones are not plugged into any devices.
  2. Sony MDR-XB450AP Extra Bass Headphones Cushion Replacement: 2 단계, 이미지 1개 중 1개
    • Using the plastic opening tools, gently pry the speaker from the headphone's base.
    • There will be some tearing involved, but this is necessary to remove the original cushion.
    • The cushion is bonded to the headphones with a circular adhesive strip. If you plan on reusing the cushion, try to keep the adhesive attached to the cushion during removal. This way the cushion can be easily re-attached to the headphones after repair.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Terrance Gallaher
회원 가입일: 01/18/17
870 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 15
전체 시간: 4,720
