주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement
필요한 것
  1. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement, Swivel: 1 단계, 이미지 1개 중 1개
    • Begin by laying the headphones down flat with the speakers facing up.
    • Be sure to unplug the headphones from any other devices.
  2. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: 2 단계, 이미지 2개 중 1개 Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Next, take out the screws that hold the front plate, using a J00 screwdriver.
    • Repeat for both the left and right screws.
    • These screws are very small. It is helpful to have a spot prepared to put the screws to avoid losing pieces.
  3. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Now that the screws have been removed, pull away the plastic casing that covers the swivel piece (directly above the speaker).
  4. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Now that the swivel piece is exposed, use a J00 screwdriver to unscrew the center screw.
    • Repeat this process on both sides if necessary.
    • This center screw is the piece that retains the swivel action, unscrew completely and remove to replace.
  5. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement, Cushion: 5 단계, 이미지 1개 중 1개
    • Begin by laying the headphones down flat on a surface.
    • Make sure that the headphone speakers are facing upward.
    • Be sure to check that the headphones are not plugged into any devices.
  6. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Using the plastic opening tools, gently pry the speaker from the headphone's base.
    • There will be some tearing involved, but this is necessary to remove the original cushion.
    • The cushion is bonded to the headphones with a circular adhesive strip. If you plan on reusing the cushion, try to keep the adhesive attached to the cushion during removal. This way the cushion can be easily re-attached to the headphones after repair.
  7. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement, Speaker: 7 단계, 이미지 1개 중 1개
    • Remove the speaker from the headband to proceed.
  8. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: 8 단계, 이미지 1개 중 1개
    • Use a J0 screw driver to unscrew the four screws located underneath on the cushion.
    • The four screws are positioned around the perimeter of the speaker's surface
  9. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: 9 단계, 이미지 1개 중 1개
    • Pry open the front case using the J0 screwdriver.
  10. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: 10 단계, 이미지 1개 중 1개
    • Simply pull away the speaker component to expose the under part of the speaker.
    • The wire will still be attached to the bottom of the speaker
  11. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: 11 단계, 이미지 2개 중 1개 Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: 11 단계, 이미지 2개 중 2개
    • With the under part of the speaker exposed, remove the broken speaker from the wires and solder on the new speaker
    • Indicated on the image to the left shows the two points the speaker can be soldered
    • Use cation when performing soldering. Soldering can be dangerous if not performed correctly with care. See the iFixit guide page on soldering here.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Terrance Gallaher
회원 가입일: 01/18/17
933 평판
안내서 5개를 작성함
4가이드 댓글
Hey Thanks for The speaker replacement information of Sony MDR-XB450AP Extra Bass Headphones and if you want to buy new headphone/earphoneplaease take a look at :
https://bestigeek.com/best-earphones-und...
Thanks
Regards
Nilesh - 답글
I really love this headphones, i have this headphone but in good condition not that type. but if you want to check new pair of headphones or earphones then here is the list
https://gadgetorg.com/best-headphones-un...
Regards
prashant - 답글
I have the same headphones and the left ear cup cables are completely detached that side also has the inline controls and mic so there are four wires i dont know what to do with the inline control wires
abdullahwasif - 답글
Where we get to buy sony headphones spaeker
ANAND KRISHNAN - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 88
전체 시간: 10,234
