주요 콘텐츠로 건너뛰기
Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement
필요한 것
  1. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement, Swivel: 1 단계, 이미지 1/1
    • Begin by laying the headphones down flat with the speakers facing up.
    • Be sure to unplug the headphones from any other devices.
  2. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: 2 단계, 이미지 1/2 Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: 2 단계, 이미지 2/2
    • Next, take out the screws that hold the front plate, using a J00 screwdriver.
    • Repeat for both the left and right screws.
    • These screws are very small. It is helpful to have a spot prepared to put the screws to avoid losing pieces.
  3. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: 3 단계, 이미지 1/1
    • Now that the screws have been removed, pull away the plastic casing that covers the swivel piece (directly above the speaker).
  4. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: 4 단계, 이미지 1/1
    • Now that the swivel piece is exposed, use a J00 screwdriver to unscrew the center screw.
    • Repeat this process on both sides if necessary.
    • This center screw is the piece that retains the swivel action, unscrew completely and remove to replace.
  5. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement, Swivel Plastic Cover: 5 단계, 이미지 1/1
    • With the swivel screw removed, remove the plastic casing.
  6. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: 6 단계, 이미지 1/1
    • Using a little amount of force, slide the plastic cover off of the headband.
  7. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: 7 단계, 이미지 1/1
    • Pull the plastic until the cover is fully removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Terrance Gallaher
회원 가입일: 01/18/17
870 평판
안내서 5개 작성하였습니다
댓글 한 개
Necesito la pieza, dónde la compro?
lucas2188 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 3,236
