소개
The removal of the top panel involves the removal of the front case to be able to reach the screws necessary for the removal of the top panel.
필요한 것
Open the battery pack door by moving the slider to "OPEN".
Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
We already removed the screw next to battery lock. The one close to blue plastic lock.
How to repair this part of the interior pack if my blue thing is broken
@AntoineTy - 답글
Using the spudger again, carefully pry from the top of the camera to remove the back frame.
The back frame is fragile, so use the spudger gently.
Pull the back pannel up starting at the bottom of the frame. There is a little hinge at inside the frame the top that will move up and make it much easier to remove the back panel (almost without effort)
meertdavid - 답글
The most difficult part of this disassembly is this plastic part. Very thin, flimsy and tend to easily break. Pay extra attention when prying this frame, especially the top part, between the screen hinges.
Update to my previous comment:
Remove the top case part where the shutter button, play button etc so that flimsy plastic frame can come out easily.
The back case should now be removed and look like this.
I guess not. battery stopper is on the body.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Hey Steven! This is all wrong! That's not the wright order: actually the top panel is the first part that can be removed, you don't need to tear down the rear panel and the front handgrip.. (it also may cause the damage of the rear panel!).
So, in order to remove the top panel just follow this order:
STEP 2
STEP 5 (Just the upper screw (not that one between HDMI and USB port)
STEP 6 (Just the two 4mm screws)
STEP 10
STEP 12
Its a lot easier ;)
Daniele
