주요 콘텐츠로 건너뛰기
Sony NEX-7 Battery Replacement
  1. Sony NEX-7 Battery Replacement, Battery: 1 단계, 이미지 1/2 Sony NEX-7 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
  2. Sony NEX-7 Battery Replacement: 2 단계, 이미지 1/1
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
  3. Sony NEX-7 Battery Replacement: 3 단계, 이미지 1/1
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
결론
To replace the battery, fit it in the slot, then close and lock the door.
다른 2명이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 04/22/14
569 평판
안내서 1개 작성함
Cal Poly, Team 10-55, Amido Spring 2014 Cal Poly, Team 10-55, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G55
4 회원들
안내서 31개 작성하였습니다
댓글 한 개
I’ve done this about a million times. :)
Martin Hurley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 16
전체 시간: 2,034
