소개
Removing the lens mount is a quick process that is fully outlined by this guide.
필요한 것
If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
Pull the card out with your fingers.
With the front of the camera facing you, remove the four silver #00 Phillips screws from the metal lens mount.
다른 5명이 해당 안내서를 완성하였습니다.
