주요 콘텐츠로 건너뛰기
Sony NWZ-E473 Audio Jack Replacement
필요한 것
  1. Sony NWZ-E473 Audio Jack Replacement, Back Panel: 1 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473 Audio Jack Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473 Audio Jack Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473 Audio Jack Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473 Audio Jack Replacement: 5 단계, 이미지 1/3 Sony NWZ-E473 Audio Jack Replacement: 5 단계, 이미지 2/3 Sony NWZ-E473 Audio Jack Replacement: 5 단계, 이미지 3/3
    • Remove the back plate from the device.
  6. Sony NWZ-E473 Audio Jack Replacement, Audio Jack: 6 단계, 이미지 1/1
    • Unscrew one 2.5 mm screw using a Phillips #00 screwdriver on bottom right portion of device located near audio jack.
  7. Sony NWZ-E473 Audio Jack Replacement: 7 단계, 이미지 1/2 Sony NWZ-E473 Audio Jack Replacement: 7 단계, 이미지 2/2
    • Disconnect the headphone jack connection from the motherboard using any tool to remove black audio piece that needs to be replaced.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chaz
회원 가입일: 01/16/15
119 평판
안내서 1개 작성함
USF Tampa, Team 17-6, Watkins Winter 2015 USF Tampa, Team 17-6, Watkins Winter 2015 회원
USFT-WATKINS-W15S17G6
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 1,066
