소개
To complete this Sony NWZ-E473 guide, you will need a screw driver and a prying device. Caution is advised when prying the back panel because permanent damage may occur if done incorrectly.
필요한 것
Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
