주요 콘텐츠로 건너뛰기
Sony NWZ-E473 Battery Replacement
필요한 것
  1. Sony NWZ-E473 Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473 Battery Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473 Battery Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473 Battery Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473 Battery Replacement: 5 단계, 이미지 1/3 Sony NWZ-E473 Battery Replacement: 5 단계, 이미지 2/3 Sony NWZ-E473 Battery Replacement: 5 단계, 이미지 3/3
    • Remove the back plate from the device.
  6. Sony NWZ-E473 Battery Replacement, Battery: 6 단계, 이미지 1/2 Sony NWZ-E473 Battery Replacement, Battery: 6 단계, 이미지 2/2
    • Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
  7. Sony NWZ-E473 Battery Replacement: 7 단계, 이미지 1/2 Sony NWZ-E473 Battery Replacement: 7 단계, 이미지 2/2
    • Slide a prying tool underneath the top portion of the battery and lift it from the case.
  8. Sony NWZ-E473 Battery Replacement: 8 단계, 이미지 1/1
    • Remove the stickers from the battery terminals, which are on the underside of the battery.
  9. Sony NWZ-E473 Battery Replacement: 9 단계, 이미지 1/1
    • Use a soldering iron to remove the wires from the red and the black terminals.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Matthew Hintz
회원 가입일: 01/16/15
327 평판
안내서 3개 작성하였습니다
USF Tampa, Team 17-6, Watkins Winter 2015 USF Tampa, Team 17-6, Watkins Winter 2015 회원
USFT-WATKINS-W15S17G6
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Hi their I have a Sony nwz-e355 walkman I want to replace the battery in it cause I thinks it's done I see u do a replacement for the e473 wondering if u have e355 batteries or will this e473 battery work in my walkman both need to be soildered in any feed back would help
Derek Hebert - 답글
I have the same model. I have 2 of them purchased years ago from Ubid.com. A very cool device. SONY ought to service them when the batteries fade…
guy lewit -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 37
전체 시간: 9,502
