소개
Underneath the metal platter, there are 2 plastic gears. These gears are used to move the tone arm while the turntable is on. If the tonearm is not moving properly during usage, these gear may be the problem. This guide shows how to replace them
필요한 것
Lift the rubber mat, and put it to the side. It should be easy to remove, because it simply rests on a metal platter without anything securing it down.
Use screwdriver to remove the four Phillips #2 screws holding in the gears.
Remove the large gear.
To reassemble your device, follow solder the wire back, screw the gears back in, and step one in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
The directions in this guide work for the PS-LX310BT and the spindle assembly replacement part works with it as well. I can confirm this, I ordered a replacement spindle assembly because mine was bent and it worked perfectly.
Cr4shMyCar - 답글
