주요 콘텐츠로 건너뛰기
Sony PS-LX300USB Gears Replacement
필요한 것
  1. Sony PS-LX300USB Gears Replacement, Drive Belt: 1 단계, 이미지 1/2 Sony PS-LX300USB Gears Replacement, Drive Belt: 1 단계, 이미지 2/2
    • Lift the rubber mat, and put it to the side. It should be easy to remove, because it simply rests on a metal platter without anything securing it down.
  2. Sony PS-LX300USB Gears Replacement: 2 단계, 이미지 1/1
    • Turn the platter so that the motor pulley can be seen through one of the two outer holes in the platter.
    • If the drive belt is hooked around the motor pulley, unhook it.
    • When reassembling to device, don't forget to hook the new drive belt to the motor pulley.
  3. Sony PS-LX300USB Gears Replacement: 3 단계, 이미지 1/1
    • Grasping the platter by its two inner holes, lift it upwards.
    • Removing the platter may take a small amount of force. If the pulley is unhooked and the tone arm is safely to the side, don’t fear using a small amount of force in lifting the platter.
    • If you haven’t yet unhooked the drive belt, the motor pulley and the belt could sustain damage.
  4. Sony PS-LX300USB Gears Replacement: 4 단계, 이미지 1/2 Sony PS-LX300USB Gears Replacement: 4 단계, 이미지 2/2
    • Peel the drive belt from the inner ridge of the metal platter and put it to the side.
    • Sometimes, the drive belt can fall off the platter during deconstruction. If this is the case, simply take it out of the device wherever it is.
  5. Sony PS-LX300USB Gears Replacement, Gears: 5 단계, 이미지 1/1
    • Use screwdriver to remove the four Phillips #2 screws holding in the gears.
    • Remove the large gear.
  6. Sony PS-LX300USB Gears Replacement: 6 단계, 이미지 1/1
    • Desolder the ground wire from its base.
    • Remove the small gear and its base.
  7. Sony PS-LX300USB Gears Replacement: 7 단계, 이미지 1/1
    • Place the replacement small gear in its position.
    • Push and hold the metal knob close to the spring.
  8. Sony PS-LX300USB Gears Replacement: 8 단계, 이미지 1/1
    • While holding the knob back, place the large gear inside with the open part of the gear facing away from the small gear.
    • Release the knob and spin the large gear counterclockwise.
결론
To reassemble your device, follow solder the wire back, screw the gears back in, and step one in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher Slaughter
회원 가입일: 09/27/17
401 평판
안내서 2개 작성하였습니다
Cal Poly, Team S8-G3, Banghart Fall 2017 Cal Poly, Team S8-G3, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G3
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
The directions in this guide work for the PS-LX310BT and the spindle assembly replacement part works with it as well. I can confirm this, I ordered a replacement spindle assembly because mine was bent and it worked perfectly.
Cr4shMyCar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 26
전체 시간: 2,963
