주요 콘텐츠로 건너뛰기
Sony PlayStation 3D Display 3D Sync Transmitter Replacement
필요한 것
  1. Sony PlayStation 3D Display 3D Sync Transmitter Replacement, Rear Case: 1 단계, 이미지 1/2 Sony PlayStation 3D Display 3D Sync Transmitter Replacement, Rear Case: 1 단계, 이미지 2/2
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 2 단계, 이미지 1/3 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 2 단계, 이미지 2/3 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 2 단계, 이미지 3/3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 3 단계, 이미지 1/2 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 3 단계, 이미지 2/2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 4 단계, 이미지 1/3 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 4 단계, 이미지 2/3 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 4 단계, 이미지 3/3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display 3D Sync Transmitter Replacement, 3D Sync Transmitter: 5 단계, 이미지 1/2 Sony PlayStation 3D Display 3D Sync Transmitter Replacement, 3D Sync Transmitter: 5 단계, 이미지 2/2
    • With the Phillips #01 screwdriver, remove the two 5 mm length x 7 mm head screws that hold the 3D Sync Transmitter in place.
  6. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 6 단계, 이미지 1/1
    • Carefully pry off the 3D Sync Transmitter with the plastic opening tool.
    • Use the plastic opening tool to pry at both ends and not from the center as to avoid breaking the 3D Sync Transmitter.
  7. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 7 단계, 이미지 1/2 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 7 단계, 이미지 2/2
    • Pry the tab slightly up with your thumbnail and pull the connector away from the board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tia McNaughton
회원 가입일: 10/01/15
379 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-16, Maness Fall 2015 Cal Poly, Team 12-16, Maness Fall 2015 회원
CPSU-MANESS-F15S12G16
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 19
전체 시간: 2,311
