주요 콘텐츠로 건너뛰기
Sony PlayStation 3D Display Side Speakers Replacement
필요한 것
  1. Sony PlayStation 3D Display Side Speakers Replacement, Rear Case: 1 단계, 이미지 2개 중 1개 Sony PlayStation 3D Display Side Speakers Replacement, Rear Case: 1 단계, 이미지 2개 중 2개
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Side Speakers Replacement: 2 단계, 이미지 3개 중 1개 Sony PlayStation 3D Display Side Speakers Replacement: 2 단계, 이미지 3개 중 2개 Sony PlayStation 3D Display Side Speakers Replacement: 2 단계, 이미지 3개 중 3개
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Side Speakers Replacement: 3 단계, 이미지 2개 중 1개 Sony PlayStation 3D Display Side Speakers Replacement: 3 단계, 이미지 2개 중 2개
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Side Speakers Replacement: 4 단계, 이미지 3개 중 1개 Sony PlayStation 3D Display Side Speakers Replacement: 4 단계, 이미지 3개 중 2개 Sony PlayStation 3D Display Side Speakers Replacement: 4 단계, 이미지 3개 중 3개
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: 5 단계, 이미지 3개 중 1개 Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: 5 단계, 이미지 3개 중 2개 Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: 5 단계, 이미지 3개 중 3개
    • With the Phillips #01 screwdriver, remove the four 5 mm length x 7 mm head screws from the assembly (two for each side speaker).
  6. Sony PlayStation 3D Display Side Speakers Replacement: 6 단계, 이미지 3개 중 1개 Sony PlayStation 3D Display Side Speakers Replacement: 6 단계, 이미지 3개 중 2개 Sony PlayStation 3D Display Side Speakers Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the plastic plate covering the speaker.
    • When reassembling, make sure the arrow on the plastic plate is facing up.
    • Lift the speaker out of its holding tray.
  7. Sony PlayStation 3D Display Side Speakers Replacement: 7 단계, 이미지 2개 중 1개 Sony PlayStation 3D Display Side Speakers Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the speaker by depressing the white tab on the speaker wire connector.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
viharim
회원 가입일: 10/22/15
200 평판
안내서 1개를 작성함
Cal Poly, Team 12-16, Maness Fall 2015 Cal Poly, Team 12-16, Maness Fall 2015 회원
CPSU-MANESS-F15S12G16
4 회원들
안내서 8개를 작성함
댓글 한 개
Speakers in this page are out of stock, do you think these will work? https://www.amazon.com/Speaker-Speakers-...
Ferserk - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 18
지난 30일: 56
전체 시간: 2,779
