주요 콘텐츠로 건너뛰기
Sony Pulse Elite Edition Headband Replacement
필요한 것
  1. Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: 1 단계, 이미지 1/2 Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: 1 단계, 이미지 2/2
    • Remove the two 5mm Phillips #00 screws from each side of the headband connected to the metal track.
  2. Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: 2 단계, 이미지 1/2 Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: 2 단계, 이미지 2/2
    • After removing the screws, push the small plastic protector on one of the sides towards the speaker closest to it.
    • After the protector has slid out of its slot, pull it away from the bar until it pops off the track.
    • Repeat this process for small plastic protector on the other side.
  3. Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: 3 단계, 이미지 1/3 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: 3 단계, 이미지 2/3 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: 3 단계, 이미지 3/3
    • Using your thumb, slide the cushion on one of the two adjusting rails toward the closest speaker.
    • Once enough of the cushion has separated from the rail, pull the rest of it off.
    • Repeat the process for the other rail.
  4. Sony Pulse Elite Edition Headband Replacement, Slide Headband Off Rails: 4 단계, 이미지 1/1
    • Gently pull the headband away from one of the speaker component groups, as if expanding it. Continue pulling until it is completely off the track.
    • Remove the white and red wires from inside the headband.
    • Be sure to keep the two speakers close together since they are still linked via the speaker wires.
    • Repeat this process for the other side.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Chris Echter
회원 가입일: 01/29/15
865 평판
안내서 4개 작성하였습니다
Clemson, Team 14-2, Shirley Spring 2015 Clemson, Team 14-2, Shirley Spring 2015 회원
CLEM-SHIRLEY-S15S14G2
5 회원들
안내서 12개 작성하였습니다
댓글 한 개
have any experience with the sony gold headset, i got two of them that broke in the same spot, right at the hinge
Rich Gallagher - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 80
전체 시간: 5,803
