주요 콘텐츠로 건너뛰기
Sony RDR HX750 HX950 Disassembly
필요한 것
  1. Sony RDR HX750 HX950 Disassembly, Remove cover: 1 단계, 이미지 1/3 Sony RDR HX750 HX950 Disassembly, Remove cover: 1 단계, 이미지 2/3 Sony RDR HX750 HX950 Disassembly, Remove cover: 1 단계, 이미지 3/3
    • Remove the screws from the back and sides of the top cover.
  2. Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: 2 단계, 이미지 1/3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: 2 단계, 이미지 2/3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: 2 단계, 이미지 3/3
    • Remove the four screws that secure the hard drive mounting bracket to the bottom of the unit.
    • Unplug the two cables from the rear of the hard drive.
    • Remove the four screws from the bottom of the hard drive mounting bracket.
  3. Sony RDR HX750 HX950 Disassembly, Remove DVD player: 3 단계, 이미지 1/3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: 3 단계, 이미지 2/3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: 3 단계, 이미지 3/3
    • Remove the screws from the DVD cover
    • Remove the screws from the plastic cable holder
  4. Sony RDR HX750 HX950 Disassembly, Remove front Panel: 4 단계, 이미지 1/3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: 4 단계, 이미지 2/3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: 4 단계, 이미지 3/3
    • Insert the paper under each "click" to remove the front panel.
    • Once each "click" is loose, push the front panel gently.
    • The table of the compact disk has a little plastic piece in front that goes up to come out with a "click"
  5. Sony RDR HX750 HX950 Disassembly, Remove  DVD block: 5 단계, 이미지 1/3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: 5 단계, 이미지 2/3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: 5 단계, 이미지 3/3
    • Unplug the cables show in photo.
    • Disconnect the cable hidden on the side.
    • Remove the piece on the cd reader
  6. Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: 6 단계, 이미지 1/3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: 6 단계, 이미지 2/3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: 6 단계, 이미지 3/3
    • Under the DVD block, remove the screws as shown.
    • Remove the screws on the board.
    • Now the laser can be accessed.
  7. Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: 7 단계, 이미지 1/3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: 7 단계, 이미지 2/3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: 7 단계, 이미지 3/3
    • Inserir instruções aqui.
결론
To open this dvd recorder folow this tutorial
다른 2명이 해당 안내서를 완성하였습니다.
Cafony
회원 가입일: 02/17/15
687 평판
안내서 4개 작성하였습니다
댓글 한 개
Hello,HX950 work only with hdd 250Gb,or another,with 500 or 1000Gb ???
Cornelus - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 47
전체 시간: 5,375
