주요 콘텐츠로 건너뛰기
Sony RMT-D197A Battery Contactor Repair
필요한 것
  1. Sony RMT-D197A Battery Contactor Repair, Sony RMT-D197A Battery Contactor Repair: 1 단계, 이미지 1/2 Sony RMT-D197A Battery Contactor Repair, Sony RMT-D197A Battery Contactor Repair: 1 단계, 이미지 2/2
    • Place the remote on a solid, sturdy surface.
    • Use a putty knife to gently pry open the remote.
  2. Sony RMT-D197A Battery Contactor Repair: 2 단계, 이미지 1/2 Sony RMT-D197A Battery Contactor Repair: 2 단계, 이미지 2/2
    • Remove the front panel from the remote.
  3. Sony RMT-D197A Battery Contactor Repair: 3 단계, 이미지 1/1
    • Wear safety glasses and use caution when handling a hot soldering iron.
    • Use the soldering iron to gently desolder the damaged battery contactor.
    • Keep in mind the battery contactor can easily break so make sure to be gentle with the soldering iron.
  4. Sony RMT-D197A Battery Contactor Repair: 4 단계, 이미지 1/2 Sony RMT-D197A Battery Contactor Repair: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to remove the spring from the contactor.
  5. Sony RMT-D197A Battery Contactor Repair: 5 단계, 이미지 1/1
    • Use the soldering iron to melt solder onto the empty hole.
    • Make sure to accurately place the spring into the correct position.
  6. Sony RMT-D197A Battery Contactor Repair: 6 단계, 이미지 1/2 Sony RMT-D197A Battery Contactor Repair: 6 단계, 이미지 2/2
    • Reattach the two halves of the remote.
  7. Sony RMT-D197A Battery Contactor Repair: 7 단계, 이미지 1/1
    • Insert batteries and try out your remote.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Ahmed Sultan
회원 가입일: 09/10/21
193 평판
안내서 1개 작성함
York University, Team 2-10, O'Regan Fall 2021 York University, Team 2-10, O'Regan Fall 2021 회원
YORK-O'REGAN-F21S2G10
1 회원
안내서 2개 작성하였습니다
댓글 한 개
As the remote is already disassembled, I took the opportunity to clean the contacts for all the buttons using alcohol.
Jason Lee - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 28
전체 시간: 431
