주요 콘텐츠로 건너뛰기
Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement
필요한 것
  1. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement, Sony Radio Model CFD S05 Prerequisite steps Replacement: 1 단계, 이미지 1/1
    • Unscrew the screws on the top of the radio.
  2. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: 2 단계, 이미지 1/2 Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: 2 단계, 이미지 2/2
    • Open the CD and cassette doors and remove the screws in the compartments.
    • To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
  3. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: 3 단계, 이미지 1/1
    • Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
  4. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: 4 단계, 이미지 1/1
    • Remove the top of the radio enough to access the wires for removal.
    • Do not forcefully remove the whole top piece of the radio! There will be wires connected to the top cover and circuit board.
  5. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: 5 단계, 이미지 1/1
    • Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
    • This should include three sets of red and white wires, one set of white wires, one set of black wires, and two ribbon wires. Some cannot be disconnected from the top piece of the radio. Disconnect these plugs from the circuit board.
  6. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement, Audio in Jack: 6 단계, 이미지 1/1
    • Unscrew the screws on the top right and top left of the back side of the buttons of the radio.
  7. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: 7 단계, 이미지 1/1
    • Pull out the buttons of the radio from the inside.
  8. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: 8 단계, 이미지 1/1
    • Pull out the audio in jack which is located on the right side of the radio directly below where the buttons are.
  9. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: 9 단계, 이미지 1/1
    • Remove the audio in jack from the circuit board by pulling on the wires where they are connected to the board.
  10. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: 10 단계, 이미지 1/1
    • Connect the new audio in jack wires to the circuit board where the old one used to be.
  11. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: 11 단계, 이미지 1/1
    • Insert the new audio in jack into the hole on the back side of the front face of the radio.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Ian Nussman
회원 가입일: 10/25/13
959 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S2G5
2 회원들
안내서 6개 작성하였습니다
댓글 2개
En français cela serrais mieux
louis roy - 답글
Vielen lieben Dank für diese Info. Habe den Kasettenspieler erfolgreich repariert. Freut mich riesig. Danke danke!!! :-)
Bernhard Cronje - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 28
전체 시간: 2,904
