소개
If either the audio, micro USB or AC adapter fails to work, they will all need to be replaced because they apart of one unit.
필요한 것
Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
Once the back cover has been removed locate the battery in the bottom right corner of the device.
Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
Using a screwdriver remove the four 1.4 mm screws that are holding the black plastic casing in place.
Using a Phillips head screwdriver, remove the two 1.4 mm screws from the bottom panel of the device.
Using the same screwdriver, remove the 1.4 mm screw that is located on the back of the device.
Using a Phillips head screwdriver, remove the one 1.4 mm screw holding in the motherboard.
Using the flat end of the spudger, flip up the 4 latches holding down the thin, orange strips that connect the motherboard to the screen, audio/AC adapter/micro USB ports, and SD card/PRODuo ports.
To disconnect the the screen, audio/AC adapter/micro USB ports, and SD card/PRODuo ports pull each orange slip away from their corresponding latch.
Using a Phillips head screwdriver, remove the three 1.4 mm screws located on the memory card holder.
Using a Phillips head screwdriver, remove the three 1.4 mm screws located on the SD/memory card holder.
Remove the SD/memory card holder from the device.
Remove the two 1.4 mm screws that are located on the audio/AC adapter/mini USB ports.
Lift up and remove the audio/micro USB/ AC adapter jacks.
다른 한 분이 해당 안내서를 완성하였습니다.
