주요 콘텐츠로 건너뛰기
Sony Reader Touch Edition PRS-600 Battery Replacement
필요한 것
  1. Sony Reader Touch Edition PRS-600 Battery Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Sony Reader Touch Edition PRS-600 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Sony Reader Touch Edition PRS-600 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • This is what the device should look like once the back cover panel has been removed.
  4. Sony Reader Touch Edition PRS-600 Battery Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
  5. Sony Reader Touch Edition PRS-600 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Terrika Ngobili
회원 가입일: 10/13/14
857 평판
안내서 7개를 작성함
Clemson, Team 1-4, Benson Fall 2014 Clemson, Team 1-4, Benson Fall 2014 회원
CLEM-BENSON-F14S1G4
4 회원들
안내서 22개를 작성함
2가이드 댓글
It works great - thanks very much for this guide!
kitimatwoz - 답글
where can i buy the battery for replacement ?? what battery is ? Answer me pls on: edgarjacob16@gmail.com
Edgar Jacob - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 50
전체 시간: 5,575
