주요 콘텐츠로 건너뛰기
Sony Reader Touch Edition PRS-600 Power Button Replacement
필요한 것
  1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Sony Reader Touch Edition PRS-600 Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Sony Reader Touch Edition PRS-600 Power Button Replacement: 3 단계, 이미지 1개 중 1개
    • This is what the device should look like once the back cover panel has been removed.
  4. Sony Reader Touch Edition PRS-600 Power Button Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
  5. Sony Reader Touch Edition PRS-600 Power Button Replacement: 5 단계, 이미지 1개 중 1개
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
  6. Sony Reader Touch Edition PRS-600 Power Button Replacement, Power Button: 6 단계, 이미지 1개 중 1개
    • Remove the stylus from the device.
  7. Sony Reader Touch Edition PRS-600 Power Button Replacement: 7 단계, 이미지 3개 중 1개 Sony Reader Touch Edition PRS-600 Power Button Replacement: 7 단계, 이미지 3개 중 2개 Sony Reader Touch Edition PRS-600 Power Button Replacement: 7 단계, 이미지 3개 중 3개
    • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
    • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
    • Pry apart off the top panel of the device.
결론
작성자
3다른 기여자 명과 함께
Zachary Jeffers
회원 가입일: 10/13/14
412 평판
안내서 4개를 작성함
Clemson, Team 1-4, Benson Fall 2014 Clemson, Team 1-4, Benson Fall 2014 회원
CLEM-BENSON-F14S1G4
4 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 732
