필요한 것
Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
Once the back cover has been removed locate the battery in the bottom right corner of the device.
Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
Using a screwdriver remove the four 1.4 mm screws that are holding the black plastic casing in place.
Using a Phillips head screwdriver, remove the three 1.4 mm screws located on the memory card holder.
