필요한 것
Remove the 6 philips head screws using the screwdriver and the PH1 bit
Remove the ribbon wire and the connector coming from the battery pack to the circuit board.
These connectors will not easily pull out, so you might have to give them a tug. They aren't very fragile, so don't worry about shredding them.
After this step, simply insert a new circuit board and you're done! Reassemble the speaker and start jamming!
can you please tell me where I can I get a new circuit board for this speaker from ?
can you please tell me where I can I get a new circuit board for this speaker from?
다른 2명이 해당 안내서를 완성하였습니다.
댓글 5개
Where did you buy the circuit board?
Hi Andrew,
Can you tell me where I can purchase a replacement circuit board? I’m having trouble finding it online.
Part number is SONY 40BKB537U-CNF2G .
Thanks!
Where can I buy the circuit board and if you want me to buy it from you fine but tell us or tell me
Thanks
Jose reyes - 답글
Donde puedo conseguir esas refacines
