주요 콘텐츠로 건너뛰기
Sony SRS-X3 Battery Charging Port Replacement
필요한 것
  1. Sony SRS-X3 Battery Charging Port Replacement, Battery Charging Port: 1 단계, 이미지 1개 중 1개
    • Remove the 6 10mm Philips head screws shown, using a PH1 screwdriver
  2. Sony SRS-X3 Battery Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 5 8mm Philips head screws shown. These are holding the battery and the green circuit board in.
  3. Sony SRS-X3 Battery Charging Port Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the battery pack and circuit board out of the housing and locate the wires and ribbon connector shown in the figure.
  4. Sony SRS-X3 Battery Charging Port Replacement: 4 단계, 이미지 2개 중 1개 Sony SRS-X3 Battery Charging Port Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the ribbon connector and the connector from the battery pack (Note: These connectors are not easy to remove. Force may be necessary but the connectors are durable)
    • After the connections are remove you are free to replace the circuit board.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
bradley
회원 가입일: 01/17/17
263 평판
안내서 1개를 작성함
12가이드 댓글
Bradley, this is a SONY 40BKB537U-CNF2G board….where can I get one? The mini charge port is bad on mine and v difficult to replace.
Thanks
michael ruse - 답글
Where can I buy the whole circuit board to replace the Charging port
Sony Mini speaker SRS - X3
40BKB537U - CNF2G
charging port
Morgan -
Where can I buy circuit board To replace charging port Sony Mini speaker SRS - X3
40BKB537U-CNF2G
Morgan -
Hi Michael, did you find a replacement board? I need to replace mine as well.
Julie Miller -
I have all the part of this speaker. Email me to negotiate! Kennyportillo99@gmail.com
kennycontreras44 -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 42
전체 시간: 7,373
