소개
The guide will demonstrate the steps necessary to replace a bad battery charging port with a new one. The speaker will be disassembled from a fully assembled condition by following the necessary steps listed in this guide to replace the faulty charging port. For this repair guide only a Phillips screwdriver and the replacement board are necessary. This replacement is very straight forward and very simple for a beginner.
필요한 것
Lift the battery pack and circuit board out of the housing and locate the wires and ribbon connector shown in the figure.
Remove the ribbon connector and the connector from the battery pack (Note: These connectors are not easy to remove. Force may be necessary but the connectors are durable)
After the connections are remove you are free to replace the circuit board.
Donde puedo conseguir una placa de circuitos de mi sony srs x-33?
Dimana kita bisa beli
Jika ada tempat kami membeli bolehkah anda menunjukkan toko dan alamatxa saya ingin mengganti suku cadang modul charger speker sony srs x3 kami
다른 5명이 해당 안내서를 완성하였습니다.
댓글 11개
Bradley, this is a SONY 40BKB537U-CNF2G board….where can I get one? The mini charge port is bad on mine and v difficult to replace.
Thanks
Where can I buy the whole circuit board to replace the Charging port
Sony Mini speaker SRS - X3
40BKB537U - CNF2G
charging port
Morgan -
Where can I buy circuit board To replace charging port Sony Mini speaker SRS - X3
40BKB537U-CNF2G
Morgan -
Hi Michael, did you find a replacement board? I need to replace mine as well.
I have all the part of this speaker. Email me to negotiate! Kennyportillo99@gmail.com
Hi, I have this same problem, broken USB charging port. The soldering looks very fiddly to me, so I would prefer to buy a complete new replacement board if anyone knows where to source it?
Thanks.
Hi Clive, did you find a replacement board? I need to replace mine as well.
Seems it's a big secret on where to get the USB circuit board , no one is answering the question
Hi, no I haven’t found a replacement board. I kind of forgot about this (bought a Marshall speaker instead ;-) ), but have just found this speaker at the back of my cupboard and still want to repair it. Has anyone found these small powerboards anywhere?
