주요 콘텐츠로 건너뛰기
Sony SRS-X3 Battery Replacement
필요한 것
  1. Sony SRS-X3 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the 6 philips head screws using the PH1 bit.
  2. Sony SRS-X3 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the 3 philips head screws holding in the green circuit board
  3. Sony SRS-X3 Battery Replacement: 3 단계, 이미지 1/1
    • Unclip the battery pack and replace it with another one.
    the flat cable being short might disconnect.
    If so reconnect the flat cable then connect the battery
    sylvain erdman - 답글
결론
다른 6명이 해당 안내서를 완성하였습니다.
Seth Taylor Rollins
회원 가입일: 01/17/17
221 평판
안내서 1개 작성함
댓글 3개
Can you give the battery # on this please
Dan Clark - 답글
Good instructions. I had one problem when removing the green circuit card. The ribbon cable came out. On mine there was a small black retention bar that I flipped open to allow the ribbon cable to reinsert, then I returned the retention bar back down to secure the ribbon cable in place. It worked fine after that.
Harpo - 답글
It would be nice if the article addressed the 6 rubber pads that cover the screws. There doesn't seem to be a way to remove them without damaging them, and you need them in order to use the speaker without it rattling and moving about from vibrations.
Peter Nosko - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 27
30일 전: 90
전체 시간: 6,725
