필요한 것
Unclip the battery pack and replace it with another one.
the flat cable being short might disconnect.
If so reconnect the flat cable then connect the battery
다른 6명이 해당 안내서를 완성하였습니다.
댓글 3개
Good instructions. I had one problem when removing the green circuit card. The ribbon cable came out. On mine there was a small black retention bar that I flipped open to allow the ribbon cable to reinsert, then I returned the retention bar back down to secure the ribbon cable in place. It worked fine after that.
It would be nice if the article addressed the 6 rubber pads that cover the screws. There doesn't seem to be a way to remove them without damaging them, and you need them in order to use the speaker without it rattling and moving about from vibrations.
