주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Sony SRS-X3 수리는 저희 서비스 설명서를 사용하십시오.
  1. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown, Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 1 단계, 이미지 1/2 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown, Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 1 단계, 이미지 2/2
    • There are 6 screws under the rubber feet on the bottom. Removing them allows the bottom plate to be removed, and then from there, the front panel, front cover, and battery compartment.
    • if you need higher reslution photos please leave a comment.
  2. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 2 단계, 이미지 1/3 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 2 단계, 이미지 2/3 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 2 단계, 이미지 3/3
    • Photos of the Main PCB. IC part numbers can be read off the photos.
    • DC to DC power supply and Yamaha audio amp chip/output filter inductors are the main parts of this side
  3. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 3 단계, 이미지 1/3 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 3 단계, 이미지 2/3 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 3 단계, 이미지 3/3
    • More images of the main board assembly.
    • The pinouts of the main flex are actually stated on the board which is a huge plus.
    • A CSR Bluetooth SoC and MXIC flash are provided.
  4. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 4 단계, 이미지 1/2 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 4 단계, 이미지 2/2
    • The battery pack is on a connector and can be removed before all of this is taken out.
    • Battery is a 2 cell 18650 pack with protection built in; 7.4V
  5. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 5 단계, 이미지 1/2 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 5 단계, 이미지 2/2
    • Two 7W speakers with strong magnets are included in this speaker; it is marketed with a 20W power output. Excursion is about 7-10mm at its peak.
  6. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 6 단계, 이미지 1/2 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 6 단계, 이미지 2/2
    • Two passive radiators are present inside the device. They're fairly heavy but rubberized, and they resonate and are tuned for low frequency reproduction. These move a LOT when it's playing. 7-10mm per side.
Larry Chen
회원 가입일: 04/22/13
913 평판
안내서 5개 작성하였습니다
댓글 10개
This is great, thank you Larry. I'd wondered about the possibility of upgrading the battery to one that lasts longer between charges but I had no idea how to open the case. It didn't occur to me that the screws would be under the rubber feet!
Steve MacDonald - 답글
Dear Larry, can you give me capture specific card power close to battery. Because i got resistor blown in that card, and i don't know specific value of this resistor. Many Thanks in advance
didi - 답글
One speaker started to give a lot of distortion making it unusable. Repositioned speaker in the heavy (magnet) housing and it's all good again.
Thank you for the opening tips and pics!
Albert - 답글
Larry,
My mini connector for dc into the board has broken. Replace connector or the whole Board? Where can I get a Power Board?
michael ruse - 답글
Where could I find the replacement speaker? My right speaker is buzzing a little on certain songs. Thanks!
Aaron Todd - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 35
전체 시간: 8,546
