소개
On this guide, the aim is to teach how to disassemble the Sony SRS-X3 bluetooth speaker in order to replace the speakers in the unit. This teardown is fairly simple, and only requires two tools. This speaker replacement is being completed because of a humming sound coming from the unit when music is being played.
필요한 것
Pop off the front speaker face (dark grey with little holes) by pushing out 3 tabs where screws were previously located and sticking the spudger in the crack where grey speaker face meets the outer shell.
You may really have to pry on this part; it is not easy to remove and will pop out when released.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 4개
Where would I get the new speakers from tho? Thanks a lot
Ruben Götz - 답글
Where I can buy one speaker as a spare part?
I would also like to know where I can get a replacement speaker
Aaron Todd - 답글
This SRS X3 cannot be used with the dc in 5v plugged, how can i do to make it work continuously with the charge cable? It have to be hacked? thanks
