주요 콘텐츠로 건너뛰기
Sony SRS-X5 Bluetooth Replacement
필요한 것
  1. Sony SRS-X5 Bluetooth Replacement, Battery: 1 단계, 이미지 1/1
    • To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
    • Make sure the speaker is unplugged and powered down before doing any work on the device.
  2. Sony SRS-X5 Bluetooth Replacement: 2 단계, 이미지 1/2 Sony SRS-X5 Bluetooth Replacement: 2 단계, 이미지 2/2
    • Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
    • Remove the bottom panel of the speaker.
  3. Sony SRS-X5 Bluetooth Replacement: 3 단계, 이미지 1/1
    • Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
    • Remove the battery.
  4. Sony SRS-X5 Bluetooth Replacement, Speaker: 4 단계, 이미지 1/1
    • To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
  5. Sony SRS-X5 Bluetooth Replacement: 5 단계, 이미지 1/1
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
  6. Sony SRS-X5 Bluetooth Replacement: 6 단계, 이미지 1/2 Sony SRS-X5 Bluetooth Replacement: 6 단계, 이미지 2/2
    • Using the plastic opening tool, flip open the speaker panel.
  7. Sony SRS-X5 Bluetooth Replacement: 7 단계, 이미지 1/3 Sony SRS-X5 Bluetooth Replacement: 7 단계, 이미지 2/3 Sony SRS-X5 Bluetooth Replacement: 7 단계, 이미지 3/3
    • Unplug the 6-pin speaker connector and 2-pin microphone connector from the motherboard by squeezing the sides of the plastic ends.
  8. Sony SRS-X5 Bluetooth Replacement, Bluetooth: 8 단계, 이미지 1/2 Sony SRS-X5 Bluetooth Replacement, Bluetooth: 8 단계, 이미지 2/2
    • Unplug the cord connected to the motherboard by squeezing the plastic sides.
  9. Sony SRS-X5 Bluetooth Replacement: 9 단계, 이미지 1/1
    • Gently tug on the plastic ribbon connected to the bottom side of the speaker to unplug it.
  10. Sony SRS-X5 Bluetooth Replacement: 10 단계, 이미지 1/1
    • Remove the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jeffrey Yalung
회원 가입일: 09/28/16
460 평판
안내서 3개 작성하였습니다
댓글 한 개
Muy bueno! Gracias Jeffrey!.
LUIS CARLOS MEJIA DIAZ - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 18
전체 시간: 1,983
