소개
This guide will show how to replace the speaker component of the Sony SRS-X5.
필요한 것
To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 10개
Help :)
Where can i buy a New speaker ?
Best regard Olav
olavfberge - 답글
lol everywhere i go to find the replacement speaker i find more people trying to find it…. really want to fix my speaker..ffs
is there not a single soul that know the answer, why is this so hard to find out. im starting a company in loose speaker cones
Excellent!!! Thank you : )
Many thanks. Now I just need to find a replacement speaker!
