주요 콘텐츠로 건너뛰기
Sony SRS-X5 Speaker Replacement
필요한 것
  1. Sony SRS-X5 Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
    • Make sure the speaker is unplugged and powered down before doing any work on the device.
  2. Sony SRS-X5 Speaker Replacement: 2 단계, 이미지 1/2 Sony SRS-X5 Speaker Replacement: 2 단계, 이미지 2/2
    • Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
    • Remove the bottom panel of the speaker.
  3. Sony SRS-X5 Speaker Replacement: 3 단계, 이미지 1/1
    • Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
    • Remove the battery.
  4. Sony SRS-X5 Speaker Replacement, Speaker: 4 단계, 이미지 1/1
    • To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
  5. Sony SRS-X5 Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
  6. Sony SRS-X5 Speaker Replacement: 6 단계, 이미지 1/2 Sony SRS-X5 Speaker Replacement: 6 단계, 이미지 2/2
    • Using the plastic opening tool, flip open the speaker panel.
  7. Sony SRS-X5 Speaker Replacement: 7 단계, 이미지 1/3 Sony SRS-X5 Speaker Replacement: 7 단계, 이미지 2/3 Sony SRS-X5 Speaker Replacement: 7 단계, 이미지 3/3
    • Unplug the 6-pin speaker connector and 2-pin microphone connector from the motherboard by squeezing the sides of the plastic ends.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Carrie Cutler
회원 가입일: 09/28/16
500 평판
안내서 2개 작성하였습니다
댓글 10개
Help :)
Where can i buy a New speaker ?
Best regard Olav
olavfberge - 답글
lol everywhere i go to find the replacement speaker i find more people trying to find it…. really want to fix my speaker..ffs
bollebaab-bouwer -
is there not a single soul that know the answer, why is this so hard to find out. im starting a company in loose speaker cones
bollebaab-bouwer -
Excellent!!! Thank you : )
Mick Talmadge - 답글
Many thanks. Now I just need to find a replacement speaker!
Lesley Packwood - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 40
전체 시간: 4,047
