소개
Use this guide to replace the battery of your Sony SRS-X55 speaker.
필요한 것
Remove the six screw covers with a spudger.
Remove the six 11 mm Phillips screws from the bottom panel.
Remove the bottom panel of the speaker.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 6개
I was just looking at the battery Jed Pause and it is made in China, manufactured in China, assembled in China ~ so no batter available in America ~ have to go to China to get it! which is very likely that you can ~ Just bring the battery with you and show it to seller’s on the street. Someone will find you the right place ~
