소개
If your Sony SRS-X55 speaker won't play sound from the auxiliary jack, replacing the I/O board may resolve the problem.
필요한 것
Remove the six screw covers with a spudger.
Remove the six 11 mm Phillips screws from the bottom panel.
Remove the bottom panel of the speaker.
Remove the two Phillips screws from the I/O board.
Remove the front panel to the speaker by pushing on the two tabs in the corners.
다른 한 분이 해당 안내서를 완성하였습니다.
