주요 콘텐츠로 건너뛰기
Sony SRS-X55 I/O Board Replacement
필요한 것
  1. Sony SRS-X55 I/O Board Replacement, Battery: 1 단계, 이미지 1/3 Sony SRS-X55 I/O Board Replacement, Battery: 1 단계, 이미지 2/3 Sony SRS-X55 I/O Board Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the six screw covers with a spudger.
    • Remove the six 11 mm Phillips screws from the bottom panel.
    • Remove the bottom panel of the speaker.
  2. Sony SRS-X55 I/O Board Replacement: 2 단계, 이미지 1/1
    • Disconnect the battery cable from the motherboard.
    • Remove the battery.
  3. Sony SRS-X55 I/O Board Replacement, I/O Board: 3 단계, 이미지 1/2 Sony SRS-X55 I/O Board Replacement, I/O Board: 3 단계, 이미지 2/2
    • Remove the two Phillips screws from the I/O board.
    • Remove the front panel to the speaker by pushing on the two tabs in the corners.
  4. Sony SRS-X55 I/O Board Replacement: 4 단계, 이미지 1/1
    • Disconnect the ribbon cable from the I/O board.
    • Carefully remove the I/O board from the speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bradley Conner
회원 가입일: 01/31/16
169 평판
안내서 2개 작성하였습니다
University of Alabama, Team 1-3, Sydow campbell Spring 2016 University of Alabama, Team 1-3, Sydow campbell Spring 2016 회원
UA-SYDOW CAMPBELL-S16S1G3
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
Where can i get a new i/o board?
Kyle Workman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 22
전체 시간: 2,394
