주요 콘텐츠로 건너뛰기
Sony SRS-X55 Input Board Replacement
필요한 것
  1. Sony SRS-X55 Input Board Replacement, Input Board: 1 단계, 이미지 1/1
    • Locate the six 9 mm screws on the bottom of the SRS-X55 and remove them using a Phillips head #2 screwdriver.
  2. Sony SRS-X55 Input Board Replacement: 2 단계, 이미지 1/2 Sony SRS-X55 Input Board Replacement: 2 단계, 이미지 2/2
    • Insert a plastic spudger at the seam of the bottom panel and remove it from the rest of the speaker.
  3. Sony SRS-X55 Input Board Replacement: 3 단계, 이미지 1/3 Sony SRS-X55 Input Board Replacement: 3 단계, 이미지 2/3 Sony SRS-X55 Input Board Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Locate the battery plug and remove it using a pair of tweezers.
  4. Sony SRS-X55 Input Board Replacement: 4 단계, 이미지 1/3 Sony SRS-X55 Input Board Replacement: 4 단계, 이미지 2/3 Sony SRS-X55 Input Board Replacement: 4 단계, 이미지 3/3
    • Locate the two 3.5 mm screws on the bottom of the I/O board and remove them using a Phillips head #2 screwdriver.
  5. Sony SRS-X55 Input Board Replacement: 5 단계, 이미지 1/1
    • Use a plastic spudger to remove the I/O board from the speaker body.
  6. Sony SRS-X55 Input Board Replacement: 6 단계, 이미지 1/2 Sony SRS-X55 Input Board Replacement: 6 단계, 이미지 2/2
    • Insert a plastic spudger into the seam of the metal speaker cover and pry it downward until it releases from the speaker body.
  7. Sony SRS-X55 Input Board Replacement: 7 단계, 이미지 1/2 Sony SRS-X55 Input Board Replacement: 7 단계, 이미지 2/2
    • Locate the eight 8.9 mm screws on the face of the speaker assembly and remove them using a Phillips head #2 screwdriver.
  8. Sony SRS-X55 Input Board Replacement: 8 단계, 이미지 1/2 Sony SRS-X55 Input Board Replacement: 8 단계, 이미지 2/2
    • Insert a plastic spudger underneath one of the tabs located on the front of the speaker assembly and gently raise the speaker assembly above the rest of the speaker.
    • Continue to the next step before attempting to lift the speaker assembly from the rest of the speaker entirely to avoid damaging internal wires.
  9. Sony SRS-X55 Input Board Replacement: 9 단계, 이미지 1/3 Sony SRS-X55 Input Board Replacement: 9 단계, 이미지 2/3 Sony SRS-X55 Input Board Replacement: 9 단계, 이미지 3/3
    • Locate the two wire connections as shown underneath of the speaker assembly and unplug them using a pair of tweezers.
  10. Sony SRS-X55 Input Board Replacement: 10 단계, 이미지 1/1
    • Locate the wire connecting the motherboard and the input board under the top panel of the speaker and remove it using a pair of tweezers.
  11. Sony SRS-X55 Input Board Replacement: 11 단계, 이미지 1/3 Sony SRS-X55 Input Board Replacement: 11 단계, 이미지 2/3 Sony SRS-X55 Input Board Replacement: 11 단계, 이미지 3/3
    • Insert a plastic spudger into the seam at the edge of the top panel and gently pry it away from the rest of the speaker.
    • The spudger can be inserted laterally into the opening created by the spudger and slid along the top as shown to remove the panel in a single motion.
  12. Sony SRS-X55 Input Board Replacement: 12 단계, 이미지 1/1
    • Locate the three 4.5 mm screws on top of the speaker input board and remove them using a Phillips head #2 screwdriver.
  13. Sony SRS-X55 Input Board Replacement: 13 단계, 이미지 1/3 Sony SRS-X55 Input Board Replacement: 13 단계, 이미지 2/3 Sony SRS-X55 Input Board Replacement: 13 단계, 이미지 3/3
    • Insert a plastic spudger underneath the edge of the input board and gently pry it away from the rest of the speaker.
결론
Chris Sparzo
회원 가입일: 01/26/17
351 평판
안내서 2개 작성하였습니다
IUPUI, Team 2-3, Baechle Spring 2017 IUPUI, Team 2-3, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S2G3
3 회원들
안내서 3개 작성하였습니다
댓글 2개
Where I can find a new input board for my srs-x55??
luc belair - 답글
I want to buy the sony input board.. can u pls help me on this
prafulpu - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 6
전체 시간: 945
