주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony SRS-XB30 Battery Replacement
필요한 것
    1. Sony SRS-XB30 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • To remove the speaker grill, insert the big spudger underneath it in each corner.
      • Work around the edges to pry the grill up and off.
      댓글 쓰기
    2. Sony SRS-XB30 Battery Replacement: 2 단계, 이미지 2개 중 1개 Sony SRS-XB30 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • With the Sony logo facing towards you, use the medium spudger to lift the side plates from the internal frame.
      • This will need to be done on all four sides of the speaker to remove all four panels
      • This requires some effort because the adhesive is sticky.
      댓글 쓰기
    3. Sony SRS-XB30 Battery Replacement: 3 단계, 이미지 2개 중 1개 Sony SRS-XB30 Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Locate the four screws on the now exposed front panel.
      • Using the screwdriver with bit T7, unscrew each screw (15.0 mm long).
      댓글 쓰기
    4. Sony SRS-XB30 Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Next, remove the four outer edge screws, located on each corner of the speaker. The outer edge of the speaker is a clear plastic.
      • Use the same T7 screwdriver head here.
      • Remove each of the four corner screws (15.0 mm long).
      댓글 쓰기
    5. Sony SRS-XB30 Battery Replacement: 5 단계, 이미지 1개 중 1개
      • With a little force, carefully lift the lid of the speaker.
      • Make sure that you do not pull on the wires.
      댓글 쓰기
    6. Sony SRS-XB30 Battery Replacement: 6 단계, 이미지 3개 중 1개 Sony SRS-XB30 Battery Replacement: 6 단계, 이미지 3개 중 2개 Sony SRS-XB30 Battery Replacement: 6 단계, 이미지 3개 중 3개
      • Unclip the four wire connectors (that are attached to the speaker lid).
      • Disconnect the thin yellow wire (attached to the speaker lid) from its port.
      댓글 쓰기
    7. Sony SRS-XB30 Battery Replacement: 7 단계, 이미지 1개 중 1개
      • Separate the speaker lid from the bottom frame.
      • To prepare the speaker for the next step place the lid parallel to the frame.
      댓글 쓰기
    8. Sony SRS-XB30 Battery Replacement: 8 단계, 이미지 1개 중 1개
      • Locate the two silver screws (9 mm) attached to the two LED-light-chips on the speaker lid.
      • Using the screwdriver with bit PH1, unscrew each screw.
      댓글 쓰기
    9. Sony SRS-XB30 Battery Replacement: 9 단계, 이미지 1개 중 1개
      • Separate the speaker lid entirely from the bottom frame.
      댓글 쓰기
    10. Sony SRS-XB30 Battery Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the top screw (10 mm).
      • Use the screwdriver with bit T7.
      댓글 쓰기
    11. Sony SRS-XB30 Battery Replacement: 11 단계, 이미지 2개 중 1개 Sony SRS-XB30 Battery Replacement: 11 단계, 이미지 2개 중 2개
      • Locate and remove the three black screws (10.0 mm) within the internal frame. Use bit T7.
      • There are two screws on the left side of the white box and one to its right.
      댓글 쓰기
    12. Sony SRS-XB30 Battery Replacement: 12 단계, 이미지 1개 중 1개
      • Slightly lift the white box with all the wires still attached.
      댓글 쓰기
    13. Sony SRS-XB30 Battery Replacement: 13 단계, 이미지 2개 중 1개 Sony SRS-XB30 Battery Replacement: 13 단계, 이미지 2개 중 2개
      • Take the big spudger and pry the black casing up from the circuit box.
      댓글 쓰기
    14. Sony SRS-XB30 Battery Replacement: 14 단계, 이미지 1개 중 1개
      • Locate the blue film attached to the circuit box containing the charging port.
      • Detach the blue film from the box.
      댓글 쓰기
    15. Sony SRS-XB30 Battery Replacement: 15 단계, 이미지 1개 중 1개
      • Detach the yellow, black and red wires by pulling them directly up.
      댓글 쓰기
    16. Sony SRS-XB30 Battery Replacement: 16 단계, 이미지 2개 중 1개 Sony SRS-XB30 Battery Replacement: 16 단계, 이미지 2개 중 2개
      • Insert the spudger along the battery edge and firmly hold the wires. Lift both sides up. The battery will pop out from its encasement.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 28명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Star Dragon
회원 가입일: 04/09/18
669 평판
안내서 3개를 작성함
9가이드 댓글
Hello. Would you upload a detailed photo of the motherboard and the built-in amplifier? I’d like to know if I could find the right IC which I want to change. Thank you! and great guide!
Santiago Gómez - 답글 공유
Can you help with what kind of battery I need? I would like to purchase it before I take everything apart. Thank you.
Betty Stewart - 답글 공유
Here you can see the answer. https://www.amazon.com/Replacement-SRS-X...
Max Bonett - 답글 공유
I really like the sound of this BT device. That´s why I own one of these. I just want to know how to convert this rechargeable speaker into AC power supply device because I don´t want to buy a battery replacement when the original one runs out. I don´t know how to calculate the volts and amperes needed to supply this speaker.
Max Bonett - 답글 공유
Which adhesive should be bought to put it all back together? Are there parts which can break or go in unoriginal form and should be romoved or fixed back together carefully? Also the link for the battery on amazon which is posted cant supply right now: is there any alternatives?
Thank you for making this guide and helping out :D
Unhappywithunrepairibility - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 57
지난 30일: 225
전체 시간: 31,986
